Hot wheels year 2000 set-complete except #15 (lotus), 23 (metrorail), 28 (67 charger), 36 (blast lane) $40
Hot wheels year 1999 set-complete except #11 (fiat), 21 (360 modena), 22 (ford panel), 26 Mercedes) $40
dog kennel $40
invisible fence system-includes collar receiver, wall unit pieces and lots of ground antenna wire. $200
dog command collar- 2 beep or shock controllers, collar receiver, recharging plug-in $50
air cleaner $10
red or blue ended braided hose covers $20 either
gen 2 Camaro 78-81 front license plate bracket new GM $30
master window switch 90s Impala SS $50
waterpump-new off crate engine. correct for 82-86 Camaro $20
Big Block valve covers new $75
Hot wheels 1997 race team IV set of 4-67 Camaro, cobra, Mercedes, 63 Vette $10
Warren Johnson autographed piece $75
57 Chev HVAC control $10
69 Chevelle marker bezel new GM $20
GM braided metal hose covering $20
ARP rocker arm stud kit Big Block 3/8" #135-7102 $30
misc hot wheels $1 ea
Dale Jr Revell die cast MIS-SPELLED BOX $30
yellow camaro $40
Franklin Mint Corvette 1:43 scale w/box $10
Franklin mint Mako Shark 1:24 scale $40
Royal Bobcat GTO 1/18 scale $40
disney plush assortment $20
parts books $20 each
I'll get the ARP rocker stud kit.
Sep 11, 2011
I will take the camaro license plate bracket. Are the Big Block valve covers tall or short?
Loren-they're short.
I'll be at work on Sat if that's an easy time for you guys to meet up, otherwise we can set up another time.
Saturdays are usually busy around here and this coming one I'll be in Warroad. I can send you a check and figure out when to get them later. I won't need them for 2-3 months.
-- Edited by Lost in the 60s on Sunday 11th of September 2011 07:54:40 PM
no problem,
I also have a set of used BBC main caps, I believe they were off a 502. make offer
I have a NEW set of 16 Valve springs from Competition Products #2427. They're spring w/dampener stock diameter, 125#@1.880350#@1.375 coilbind is 1.2 retail is $69.95 $40 for club members
According to CP's website, the springs are for a Ford 390-428...
Go through the look up process for BBC and they come up. We ordered them for our 509/609 crate engine program way back when. They also spec out for stock BBC dimensions.
camshaft: newin box gm# 14097395 HT383/ram jet crate engine cam 196/206 duration, 431/451 lift 109' centerline. $100
dog kennel $40
air cleaner $10
yellow camaro $40
http://www.competitionproducts.com/Chev-BB/products/421/
Brian, have to arrange another time, I am flying to Phoenix for work on Saturday.
Also have black 70-72 1/4 trim panels.
