For members first - last stop before the recycling yard next week
FREE / token offer 5.7l , 350 block, crank, plus parts. Pending Dave S.
Block casting 14093638, 1 pc rear, stock bore, 2 bolt, flat tappet cam with mechanical fuel pump casting still there. Crank looks good and spins freely. Greased crank and bores for long term storage, should cleanup easily.
includes:
box of std pistons and rods from 2 engines.
oil pan and front timing cover
bag of rockers from heads, gm stock self aligning
harmonic balancer
flex plate
newer gm double roller timing chain.
FREE Trek Moutian bike, need tlc Pending Clutch
FREE Samsung Syncmaster 214 monitor. It was going to be tossed at work, history unknown, so I read and found the capacitors go bad. They were, so I replaced the capacitors but only flashes the screen for a second or so. Not sure what else maybe wrong maybe a resistor / diode? I leave it to the electric guys if they want to play with it.
FREE NIB Rear rotos for 93-97 F-body. One has some surface rust from exposure to the air. Should clean up easy with steel wool, other never opened.
FREE - 2001 honda Accord radio / cd / cassette player I think I have the security code around somewhere.
-- Edited by Enganeer on Monday 1st of August 2011 08:13:03 PM
-- Edited by Enganeer on Wednesday 3rd of August 2011 07:35:01 AM
Will you be around Monday?
Could be,
PM me with a time.
Clutch said
Aug 1, 2011
I'll take the bike if it will fit a 6' 1 adult
I think it could fit. Needs some work, probably new inner tubes but priced right.
includes:
harmonic balancer
flex plate
PM me with a time.
PM me and maybe we can meet somewhere.
