Bad has helicoil in one of the holes. I cleaned it up but could use better cleaning in the tight areas. Gave a quick shot of paint. Come with orignal box.
Chevrolet sbc tall valve covers $25
MSD 6A ignition box $75
5.7l , 350 block, crank, plus parts. $40 for it all
Block casting 14093638, 1 pc rear, stock bore, 2 bolt, flat tappet cam with mechanical fuel pump casting still there. Crank looks good and spins freely. Greased crank and bores for long term storage, should cleanup easily.
box of std pistons and rods from 2 engines.
oil pan and front timing cover, bag of rockers, harmonic balancer, flex plate, newer gm double roller timing chain.
Trek Moutian bike, need a inner tube, tlc and tune up. $30
Bike carrier from my old job. Clamps around a 2" receiver hitch tang.
-- Edited by Enganeer on Wednesday 29th of June 2011 08:01:08 AM
manchu said
May 30, 2011
Sir ill take that welder I need one bad lol
Is the helmet auto-darkening? If so, dibbs.
Yes it is.
OK, then Dibbs. It's OK for 110V MIG right?
You should be fine. If its adjustable, even better. But the helmet doesnt know what voltage your welder is. Its job is to darken the ultraviolet light thats emitted.
Dang it Chris!
I could of had fun with this one.
More free stuff for members
FREE Left rear taillight for 2001-2002 honda accord
FREE Right? inner tail light for 2001-2002 honda accord.
FREE Honda radio from 2001 accrod EX. I have the secruity code somewhere.
-- Edited by Enganeer on Sunday 10th of July 2011 02:23:05 PM
MHAYEN said
Jun 6, 2011
I'll take the CB radio if it has not already been claimed.
Consider it yours Mike.
-- Edited by Enganeer on Monday 6th of June 2011 05:34:24 PM
Added 6-13
(2) 64-67? 10 bolt open rears 3.08 $40 each.
Add some more stuff
Free v-belts (2) I think there were for alternator.
Free Gas can.
$5 trail tounge lock. Will not work my trailer.
$10 Grant steering wheel. Too small for my taste. Need grant adaptor if your going to use. Pending to Scott.
$50 8.5 rear posi 2 series carrier. Bought from John D last winter. I have 8.2 rears :(
-- Edited by Enganeer on Saturday 2nd of July 2011 06:20:45 PM
I will take the starter, you around today?
Yes, I will be around.
Jun 21, 2011
Will that posi carrier work in a 67 Impala 12 bolt open rear end. If yes I would deffinatly be interested.
No, you would need a 12 bolt (8.875") passenger carrier. This is for a 10 bolt 8.5" rear.
MHAYEN said
Jun 22, 2011
If the air assembly is not taken, I'd claim that too! Is the Chevelle black mat for sale too???
No matt for sale, your welcome to the air assembly though.
2 Hoffman Enclosures $10 each Great boxes for the garage. Will get dimensions. they are 8" deep. - Pending to Loren
Might have a serpentine setup for sale also. I have much better fan with clutch than shown and power steering pump with quick ratio gear box (not shown). Fits sbc unless you don't have accesspry bolt holes in heads (very early heads)
-- Edited by Enganeer on Sunday 26th of June 2011 08:42:08 PM
-- Edited by Enganeer on Monday 27th of June 2011 09:44:43 AM
Jun 27, 2011
I'll take the Hoffman enclosures.
Loren,
Enclosures are marked as yours.
Will the quick ratio steering box fit on my 66 chevelle? If so I would have interest in that, let me know a price.
Jun 27, 2011
Can I have that steering wheel?
I had this setup on my 64 before I swapped to a different serpentine setup.
If you going to do a serpentine swap, it is a bolt in. If you want to retro fit it to your power steering pump, I believe there are some fitting adapters needed.
I could let the whole serpentine setup go for $150. I'll think on it if you just want the quick ratio gear box.
-- Edited by Enganeer on Monday 27th of June 2011 10:45:13 AM
Scott,
I'll mark it as yours.
Not interested in the serpentine set up just the box and power steering pump since it was matched to the box if you are willing to seperate it. What was the steering box originally from? My car does not have power steering at all, I'm sure the pump can be used to other brackets beside the serp set up.
-- Edited by 67ss on Monday 27th of June 2011 12:03:50 PM
Chris,
The box was from a 87 Pontiac Grand Prix if I recall correctly.
I am not sure the PS pump would work with non serpentine setup as the pulley hub post is for press on pulley and not a keyed pulley.
Added old school tool box $25. Some dents but sturdy with vintage bumper sticker. Tools not included.
-- Edited by Enganeer on Sunday 10th of July 2011 02:24:01 PM
Time to clear some stuff out
Edlebrock performer intake $25
Add some more stuff
Free Gas can.
Simuliar to
http://www.summitracing.com/parts/NAL-12497698/?rtype=10
Scott,
