Built by Randy Quam at Competition Engines in Eagan MN AFR 195cc heads Demon 750 Carb fancy raised letter valve covers (the $400 a pop jobs) 2,000 miles on the motor Comp Cams Xtreme Energy 284 cam Forged pistons and rods Moroso oil pan HEI distributor Edelbrock air-gap Rpm intake
Still in car, can hear run. In great shape, he has all paperwork and dyno sheets.
There's nothing wrong with this engine, but he's swapping to LS stuff and doesn't need it anymore.
That's a steal! You couldn't buy a crate engine close to this with the pedigree (Comp Engines)/documentation (dyno paperwork and can hear run) that this one has.
A few years ago, I bought a new crate 350, changed out the valve train, and by the time I bought all the bolt on parts, it was as much as this! And... it didn't put out a documented 400+ HP/TQ when done.
I know it's a good deal but I doubt he'll want $100 a month for 3 years as payment....
That would be a FUN engine in the Camaro...
May 11, 2011
The engine/owner are in White Bear- you can hear it/drive it before you buy it. This really is a good deal...but there's an LS on deck so this has to go!
The engine is in a Camaro and someone posted it on the Camaro forum too. Is that the owner ?
not mine- a pal has this available:
355 CID
445hp
445tq
$4,000
AFR 195cc heads
Demon 750 Carb
Moroso oil pan
HEI distributor
If you're interested, contact the engine's owner (Eric) at Allynwrench@hotmail.com. He's a good guy and a straight shooter- you can trust him.
