GEEZ Stan, I don't think I'd go around admitting that, but hey, good for you. At least you're owning up to it.
Speedway has FULL face helmets for $140. However they are SA05 but will still be good for at least another 5 years. http://www.speedwaymotors.com/Garage-Sale-RCI-SA05-Helmet,8685.html Personally I wouldn't use anything but a full face, but that's just me. Another thing. I've found helmets (all brands) to run a little on the small side. RCI's chart says I should have a size large but it was too tight. I had to go with an extra large. (and yes, I have a big head)
I think CA Performance stocks some helmets. Stop by, also talk to Francis @ a club meeting there again, plus maybe some advertising???
Winston Wolf said
Mar 5, 2011
Just buy one. I have this model. It is snell and I wear it at Rock Falls.
It's a HJC CL-31 model. The open face is much nicer.
-- Edited by Winston Wolf on Saturday 5th of March 2011 09:17:07 AM
Thanks Winston. That looks like a good deal.
Since you said you've used it at Rock Falls, I'm guessing the 'Snell & DOT Approved' is adequate? The ad doesn't specify which Snell rating it is approved to.
Maybe Tony H. knows.
Constructed of lightweight injection molded polycarbonate
Two piece channeled dual density expanded poly-styrene liner for shock absorption and direct channeling air flow
Channeled adjustable forehead vents with venturi rear exhaust vents create a flow-through ventilation system
Comfortable plush brushed Nylon interior with sewn-in crown pad
Nylon strap retention band with double D-ring neatly secure chin strap
Comes with 3 snap black visor
Snell and D.O.T approved
Weight of medium helmet 2lb. 9oz.
Winston Wolf said
Mar 5, 2011
I just went and looked at mine. It's SNELL 2005, so good to go for a long time.
Mar 5, 2011
Its certainly cheap enough.. If thats what you are after..
The one I listed is very similar to my Bieffe.. and probably what Ill buy to replace it when it goes out of spec.
Winston, thanks for checking the Snell rating. Looks like I'll be placing an order soon!
Tony, it's just hard for me to justify spending $150-300 for a helmet I will use once or twice a year. If I raced as much as you do, I'd definitely step up to a higher level.
Mar 5, 2011
Understood.. also keep in mind..
Snell 2000 Exprires 1-1-2012
Snell 2005 expires 1-1-2017
Snell 2010 expires 1-1-2022
Mar 5, 2011
all of this helmet talk..I realized mine iss done end of this year so I ordered the racequip..
I have a small head (no jokes about it being due to a lack of hair either please... :wink:) so would probably need a Small in size.
Let me know if you've got one.
Thanks.
Just go buy a racequip for a buck and a half.. Its SA2010 rated.. and should be good for years to come.
http://pitstopusa.com/i-5923339-racequip-open-face-helmet.html
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=3301586XXS&store=Main&catId=&productId=prod630147&leafCatId=&mmyId=
