- An "unknown" 350 - came in my '64. Ran when I pulled it. - The 383 that was in the '65. Built in mid-80's when they were strange. Have most receipts. Has about 15 to 20K miles on it. - A TH350 that was behind the 383. Trans-Go shift kit on "moderate" level. - Vintage Mallory dual-point distributor, with mechanical tach drive. - Vintage Moroso mechanical tach.
Call me and make an offer on some of this stuff.
I'll try to get ahold of a guy with a Nova, blown motor and trans that needs replacement engine and trans
Jan 15, 2011
Too bad it isn't next year as I would be very interested in that 383! Keep me posted on what happens with that as it would be neat to have that in my 4-door Chevelle!!!
-- Edited by 4-door Chevelle on Saturday 15th of January 2011 11:01:42 AM
Your heads/top end on this short block would be a neat combo - but it goes as an assembly... no parting out.
Did a little investigating on the "mystery 350" tonight. Here's what the numbers say:
I.D. pad = 10B210986 / TO627CNN (my stuff translates this into: '70, 2bbl, auto, 250HP, a/f/x body car) Driver's front of block = 014 Driver's rear (casting #) = 3970014 (translate: 350cid, 2 or 4 bolt main) Pass rear/top = clock symbol at 3:00, numbers are F23 70
Heads = #14022601 (translate: early '80s, 267 or 305, H.O., 1.84/1.50, 58cc's)
Cannot confirm if it's a 2 or 4 bolt main - I've never had the pan off.
I've got:
Brackets, pulleys, alternators, starters, PS pumps...
Heads = #14022601
