NCC Forum Home Page
Login
Menu
Cleaning garage.
Cleaning out the garage today.
Windstar electric cooling fan and factory connectors. $25
(2) Taurus fans; One with connector and stock relay box @$20, one with connector end $10
SBC tall valve covers with Chevrolet script, block powder coated, steel. $30
'65 10 bolt rear 3.08 open from my 65 El camino I parted years ago, some pitting on axle tubes but I have seen worse. $40 (Will give JohnD 1st shot).
Added free 400 sbc crank and flywheel. Crank has surface rust and should be turned. It was from a running 76' van.
-- Edited by Enganeer on Monday 9th of August 2010 07:29:53 AM
Is it a 8.2" or 8.5"?? (square "ears" on the lower corners of the pumpkin)
The rear is a 8.2.
-- Edited by Enganeer on Monday 9th of August 2010 09:26:19 PM
Post Reply
Activeboard Mobile
